Why Front-Wheel Drive Sucks.......
Geplaatst: vr jan 28, 2005 10:20
door Chiel
Gevonden op het internet........ :lol:
And why rear-wheel drive is coming back.
By Mickey Kaus
Updated Friday, April 11, 2003, at 4:06 AM PT
Car/sex metaphors are unavoidable, so let's get right to today's: Front-wheel drive cars are like bad sex. Rear-wheel drive cars are like good sex.
Let me explain!
Sometime in the early 1980s, I asked my friend Paul why he drove a crass Chevy Camaro. He said he liked the "balance" of a rear-wheel drive car. I nodded but secretly sneered at him. Everyone knew that front-wheel drive cars were the efficient, sophisticated wave of the future. Audis were front-wheel drive. Saabs were front-drive. GM, Ford, and Chrysler were about to embark on a massive shift to front-drive, resulting in the current Detroit product lineup, in which even the venerable Caddy DeVille is a front-drive car.
The advantages of front-wheel drive (FWD) seem self evident: By avoiding the need for a driveshaft connecting the engine in front with the rear wheels, front-drive cars save space. The entire drivetrain can be packed into a neat compartment in the front, leaving the rest of the car's volume for passengers and cargo. Plus, front-drive cars have better traction in slippery conditions (in part because the weight of the engine is on top of the wheels that are providing the power).
I should have realized the grim truth decades ago when I borrowed a friend's Audi 100 –- the first front-drive car I'd ever driven -- and took it out on Sunset Boulevard. In one of the curves leaving Beverly Hills, near the pink house that used to be owned by Jayne Mansfield, I mashed the throttle, expecting the satisfying "lock in" effect I got in my old rear-drive Volvo – the nose turning in, the car seeming to stop slipping, tightening its grip on the road even as it went around the corner faster. But that's not what happened. What happened is the front tires went all gooey and the car started to head for the living room of a nearby mansion. Only panicked braking calmed things down.
Naturally, my brain did what the human brain tends to do with a bit of aberrant data: I ignored it. All during the '80s and '90s the car magazines assured me, seemingly continually, that in sophisticated front-drive designs you couldn't even tell which set of tires was providing the power. Weren't front-drive Hondas the hippest cars around? Wasn't even Volvo switching, belatedly, to front drive? I also blamed the victim! I must just be a lousy or unsophisticated driver, I figured.
Then, a bit over a year ago, I conducted an abortive test drive of five convertibles. The idea was to sample cars that had at least a semblance of a rear seat. The entrants were Ford Mustang, Chevy Camaro, VW Cabriolet, Chrysler Sebring, and Toyota Solara. And that was the order of finishing (though the test was interrupted by 9/11 before I could drive a final production version of the Toyota). None of the cars was very good – you give up a lot in chassis stability when you chop off the roof, I discovered. But the old, junky, rear-drive Ford and Chevy pony cars were by far the most enjoyable – they rattled and guzzled, but at least they were a blast to drive around corners. The other three cars, all front-drive, were simply pleasant forms of transportation.
Why are rear-drive cars more fun? Every enthusiast may know the answer, but I didn't. So I called up a helpful GM suspension expert, Vehicle Chief Engineer Ed Zellner. There are, I learned, five basic reasons:
1) "Balance": The car rides on four patches of rubber, each about as big as your hand. An ideal car would distribute its weight evenly, so each tire had to bear the same load, and none would give way earlier than all the others. The ideal weight distribution, then, would be split about 50/50 between front and rear (actually, 48/52 to help with forward pitch during braking). "A rear-drive car can typically approach that," says Zellner. Engineers can move the front wheels forward, so that the engine – which doesn't have to be connected to those wheels -- sits behind the front axle. Meanwhile, the driveshaft and rear differential (necessary to send power to the rear tires) add weight in the rear. Front-drive cars, which must connect the engine and transmission to the front axle, typically have their engines mounted way forward and can't do much better than a 60/40 front/rear weight distribution.
2) Center of Gravity: This is the point the car wants to "rotate around" in a turn. On a rear-drive car, it's "about where the driver sits," says Zellner. In a turn, in other words, the car seems to be rotating around you – you're at the center. It's a natural pleasant effect, suggesting you're in control, the way you're in control when you're walking or running around a corner and your weight is centered inside you. (Analogy No. 2: It's like wearing stereo headphones and having the sound centered between your ears!) A front-drive car, in contrast, with its massive front weight bias, wants to rotate around a point in front of the driver. So in a corner, the driver isn't just rotating around his spine. He's moving sideways, as if he were a tether ball on the end of a rope, or Linus being dragged when Snoopy gets hold of his blanket. Not such a pleasant feeling, or a feeling that gives you a sense of natural control.
3) "Torque Steer": One of the most annoying habits of many powerful front-drive cars is that they don't go straight when you step on the accelerator! Instead, they pull to one side, requiring you to steer in the other direction to compensate, like on a damn boat. This "torque steer" usually happens because the drive shafts that connect the engine to the front wheels aren't the same length. Under power, the shafts wind up like springs. The longer shaft -- typically on the right -- winds up a bit more, while the shorter left shaft winds up less and transmits its power to the ground more quickly, which has the effect of pulling the car to the left. (This winding-up phenomenon occurs the moment you step on the pedal. After that, the wind-up relaxes, but "torque steer" can still be produced by the angles of the joints in the drive axles as the whole drivetrain twists on its rubber mounts.)
Engineers try various strategies to control this veering tendency, but even designing shafts of equal length (as in all Cadillacs) doesn't completely solve the problem because the engine still twists a bit in its mounts and alters the angles of the drive shafts. True, some manufacturers -- Audi, for example -- are said to do a particularly good job of repressing torque steer . But even a top-rank company such as Nissan has problems -- its otherwise appealing new front-drive Maxima is said to be plagued by big-time, uninhibited torque steer. Rear-drive cars, meanwhile, don't really have a torque-steer problem that needs repressing. Their power goes to the rear through one driveshaft to a center differential that can a) have equal-length shafts coming out from it and b) be more firmly mounted.
4) Weight Shift: Suppose you just want to go in a straight line. What's the best way to get traction? Answer: Have as much weight over the driving wheels as possible. Front-drive cars start with an advantage -- but when any car accelerates, the front end tips up, and the rear end squats down. This transfers weight to the rear wheels -- away from the driving wheels in a FWD car but toward the driving wheels in a rear-drive car, where it adds to available traction. In effect, the laws of physics conspire to give RWD cars a bit more grip where they need it when they need it. (This salutary effect is more than canceled out in slippery, wet conditions, where you aren't going to stomp on the accelerator. Then, FWD cars have the edge, in part, because they start out with so much more of their weight over both the driving and the turning wheels. Also, it's simply more stable to pull a heavy wheeled object than to push it -- as any hotel bellhop steering a loaded luggage cart knows. In snow, FWD cars have a third advantage in that they pull the car through the path the front tires create, instead of turning the front tires into mini-snowplows.)
5) "Oversteer" and the Semi-Orgasmic Lock-In Effect: In a rear-drive car, there's a division of labor -- the front tires basically steer the car, and the rear tires push the car down the road. In a FWD car, the front tires do all the work – both steering and applying the power to the road – while the rears are largely along for the ride. That, it turns out, is asking a lot of the front tires. Since the driving wheels tend to lose traction first, the front tires of front-drive cars invariably start slipping in a corner before the lightly loaded rear tires do -- a phenomenon known as "understeer." If you go too fast into a curve -- I mean really too fast -- the car will plow off the road front end first. In rear-drive cars, the rear wheels tend to lose traction first, and the rear of the car threatens to swing around and pass the front end -- "oversteer." If you go too fast into a corner in an oversteering car, the car will tend to spin and fly off the road rear end first.
What's the best way to fly off the road? Safety types prefer frontwards -- understeer. Why? To control an oversteering skid, where the rear wheels are heading for the weeds, you have to both slow down and counterintuitively turn the wheel in the opposite of the direction you're turning. In a front-drive car, with the front wheels slipping, you slow down and keep turning the way you'd been turning to get around the corner in the first place -- a more natural maneuver, since you're pointing the car in the direction you want to go. This is why, for safety reasons, even rear-drive cars sold to average consumers tend to have their springs and other suspension bits set up to make them understeer -- to make the front tires slip first, despite the car's innate oversteering tendency. Only by applying lots of power in a corner can you actually break the rear end of a bread-and-butter rear-drive car like the Mustang loose -- a maneuver favored by sports car freaks, but one you try at your own peril.
Big American manufacturers (all heavily invested in front drive) like to say that for 99 percent of drivers, driving at normal speeds, FWD's inherent understeer and better traction in the wet makes it preferable -- both safer and easier to drive quickly. It's only the 1 percent of speed freaks who enjoy breaking the rear end loose and then catching it with a bit of "reverse lock." Here's where I emphatically dissent.
It's pretty clear to me, after driving hundreds of different vehicles over several decades, that rear drive offers a big aesthetic advantage to ordinary drivers at ordinary speeds in ordinary conditions. Why? The lock-in effect I mentioned earlier. Suppose you go into a corner in a rear-drive car at a reasonable, safe, legal speed. Nothing's about to skid. But you can still feel the front end starting to plow wide a bit. What to do? Step on the gas! Don't stomp on it -- but add a bit of power, and a miraculous thing happens. The front end swings back in, the car tightens its line. Cornering traction seems to increase. And the car feels locked into a groove, balanced between the motive power from the rear and the turning power in the front.
You don't have to be a race driver to feel this. You can be a defensive driver and feel it. You can be driving a 1973 Ford Maverick with leaking shocks and you'll feel it. Accountants feel it on the way to the office and housewives feel it on the way to the Safeway. Even Ralph Nader probably feels it. It's a good part of what makes driving a car a sensual act. (What's happening, technically? None of the tires is at its limit of adhesion. But the added speed is making the front tires --which [since they are undriven] have plenty of surplus traction -- apply more force to the road surface to change direction. Meanwhile, the rear of the car is shifting outward, ever so slightly -- not a Bullitt-style power slide, but a subtle attitude adjustment that cancels the plowing effect. The power "helps you through the corner," as Zellner puts it.)
This doesn't happen in a front-drive car. The best an ordinary driver can hope for in a FWD car is that it "corners as if on rails" -- no slippage at all. No plowing -- but also no semi-orgasmic "lock in." More typically, if you hit the accelerator in a fast corner, things get mushy up front (as they did that evening near Jayne Mansfield's house). The lesson the FWD car seems to be teaching is: Try to go faster, and you're punished. Front-drive cars are Puritans! In a rear-drive car, you hit the accelerator and things get better! Rear-drive cars are hedonists. (This is assuming you don't hit the accelerator too hard.)
I'm not saying there aren't sophisticated techniques that allow FWD cars to do better. A recent issue of Grassroots Motorsports tested a humble FWD Acura RSX against a classy rear-drive BMW. The Acura actually turned laps a bit more quickly. How'd that happen? The Grassroots people realized that by stepping on the brake hard enough on entering a turn, the rear of the Acura could be made to swing wide, canceling out its inherent understeer. (This is the same effect you get by stepping on the gas in a rear-drive car.) But normal drivers aren't going to mash the brakes and go sliding through turns like a rally champion. Nor does braking to achieve "lock-in" seem as satisfying as accelerating to achieve lock in. I suppose I shouldn't knock it until I've tried it -- but I'm not going to try it! That's the point. Housewives heading to the Safeway aren't going to try it either. The joys of rear-drive are accessible to them -- it's the joys of FWD that are reserved for the skilled Grassroots Motorsport elite.
Explaining SUVs: Now that the goo-goo bien pensant scales have fallen from my eyes, and I recognize the front-drive-for-the-masses movement as the Carter-era energy crisis con it is, several previously inexplicable things become explicable. Why did truck-based SUVs suddenly become popular just as Detroit shifted to front-wheel drive for its passenger cars? Was it (as anti-SUV activists claim) because the SUVs were exempt from various safety and economy standards -- or because the SUVs still had rear-wheel drive, with all its subtle satisfactions? Why do all BMWs (and virtually all Mercedes-Benzes) persist in using rear-wheel drive? Why do my friends, who aren't fast drivers, say that BMWs just feel better?
It's also now clear to me why Acura is in trouble (it only offers FWD sedans), why GM is busy working on a new "Tubular" rear-drive chassis, why the Infiniti G-35 and Lexus IS-300 (both rear drive) are so popular, and why the RWD Cadillac CTS and Lincoln LS are so refreshing to drive.
I'm not saying that any rear-wheel-drive car is better than any front-wheel-drive car, the way, say, any car with plain black tires looks better than any car with whitewalls. But it's close! Front-drive cars can be fun. Even bad sex is fun. But why choose it?
RE: Why Front-Wheel Drive Sucks.......
Geplaatst: vr jan 28, 2005 13:41
door Blu Ollandese
Leuk geschreven, en goed uitgelegd!
Alleen ben ik niet zo zeker over zijn uitleg waarom SUV's zo populair zijn...kan toch niet enkel aan de RWD factor liggen...ik den eerder dat de "show off" factor doorslaggevend is...en de kudde mentaliteit natuurlijk...
thanks for the post!
Geplaatst: vr jan 28, 2005 14:10
door bert
Torque steer stinks! Aandrijflijn en stuurinrichting op de vooras rijdt gewoon minder prettig
en als belangrijkste is de funfactor met achterwielaandrijving vele malen groter.
door bert
Geplaatst: vr jan 28, 2005 21:14
door psillen
Mooi artikel.
En geheel correct, achterwielaandrijving rijdt prettiger :thumbs:
Geplaatst: vr jan 28, 2005 23:23
door Richard
Op gummen heeft iemand het prachtig omschreven:
RWD, die verouderde techniek die in bepaalde onveilig auto';s zoals BMW nog wel eens voorkomt en die door een sterke reclamecampagne nu zelfs door onwetenden als beter wordt gezien.
hahaha, grappig...
Nee doe mij maar een gewone goed FWD die op sneeuw en ijs veruit superieur is aan iedere RWD en allen AWD toe moet geven.
Een RWD is toch een AWD waar uit kostenaspecten een deel van de techniek is uitgeschakeld ;)
Persoonlijk maakt het mij geen klap uit of het RWD, FWD of ADW is: als het maar een Alfa is :)
Geplaatst: za jan 29, 2005 00:07
door dibro
Even "de knuppel in het hoenderhok"......:
Iemand TopGear gezien vanavond? Ze hebben middenklasser 2-liter 4-deurs sedans door hun circuit gesleurd (laten sleuren door the stig) Er was 1 RWD auto bij (een B**) en die was -niet- de snelste... Welke dan wel het snelste was weet ik raar genoeg niet meer :wink:
Zou een conclusie kunnen zijn dat RWD wel leuker maar zeker niet sneller is als FWD?
Geplaatst: za jan 29, 2005 01:17
door Blu Ollandese
Dat FWD sneller is, word in het artikel ook besproken, de professionele rijders gaan op de rem staan en slippen de bocht in....om zo ook gebruik te maken van het "lock in" effect dat je bij een RWD krijgt bij acceleratie in een bocht. Dat deed de Stig mss ook, de man weet wel hoe hij het onderste uit eender welke kan moet halen...
Daarom zijn Alfa's (tot 75) en mss ook Bmw's :roll: ook echte BELEEF-wagens...zo worden ze toch geprofileerd., en ze hebben allemaal RWD...niet dat modernere ALfa's dat niet zijn, integendeel, is gewoon een andere techniek...ander gevoel...
Ik denk dat FWD perfect is voor de huis- tuin en keukenritten (en zelfs veiliger voor de modale chauffeur bij glad wegdek) en zeker niet minder fun dan RWD, maar als er echt, mss wel op een nostalgische manier, rijdersgenot van de bovenste plank moet beleefd worden, geniet RWD gewoon de voorkeur...
Geplaatst: za jan 29, 2005 01:37
door dibro
Helemaal mee eens....
Grrr ik wil nog steeds (steeds erger) een rwd, "altijd lekker erbij".... :wink:
Geplaatst: za jan 29, 2005 10:56
door De Block
156 SW Q4, ook fijn...
Geplaatst: za jan 29, 2005 10:59
door De Block
Met een opgeboord Savali GTA blokje, wel te verstaan...
Geplaatst: za jan 29, 2005 12:26
door bert
Beleving is alles. Alles wat rijden nog meer opwindend kan maken, moet eigenlijk verplicht op een Alfa. Kleine subtiliteiten als geluid, reflexen, weggevoel etc. Ik vindt het DNA van wat
een Alfa Romeo hoort te zijn, is opgeslagen in Giulia. Als snelheid toeneemt, komt wat licht onderstuur wat gradueel overgaat in overstuur als het te hard gaat.
Bochten kunnen vloeiend worden genomen en wie bekwaam kan gaspedaal gebruiken. Stabiliteit voor wie voorzichtig is en sportief voor wie eens wat enthousiater wil rijden.
Preciese controle, vertrouwenswekkend en gecontroleerd overstuur. Het gaat niet om driften (doe je niet op openbare weg) maar om precies gevoel van een RWD. Jevoelt veel
meer betrokkenheid bij het rijden wat auto doet. FWD rijdt zichzelf en is idiotproof.
Re: RE: Why Front-Wheel Drive Sucks.......
Geplaatst: za jan 29, 2005 19:55
door AlfaGatto
Beleving is alles
waarom dan die laatste zin in je verhaal ? :wink:
voor mij geldt Alfa Romeo = uitstraling, subliem geluid en lekker knapperig rijden (in mijn beleving) en dan maakt aandrijving m.i. geen fluit uit (behalve No-Wheel-Drive dan)
Geplaatst: za jan 29, 2005 23:27
door psillen
AlfaGatto,
Het is moeilijk te omschrijven, maar iedere keer als je weer eens met een achterwielaandrijver rijdt, merk je het verschil.
Het is toch een ander gevoel.
Rij maar eens met een 75, Alfetta, Giulia, enz. BMW mag ook, maar niet te lang :twisted:
Geplaatst: zo jan 30, 2005 11:07
door Tazio Novante
Ik ga er helemaal in mee.
Hoewel mijn eerste Alfa een Sud Sprint was en een 156 en 147 beter op de weg liggen dan de 90 en Berlina, zal ik het wat voorwielaandrijvers betreft Alfa bij laten. Dat van de balans spreekt me het meest aan: 2 wielen om te sturen en 2 om aan te drijven. Dus met het stuur de voorkant onder controle houden en met het gas de achterkant.
Voorwielaandrijving is volgens mij primair een productiewens. Leve de sub-frames!
Blijft natuurlijk de vraag waarom het verschil tussen de BMW's en Alfa's in het ETCC toch naar de voorwielaandrijver doorslaat? Toch dat inremmen?
