Boxer33.mo
Alfa Romeo 33 Savali
za apr 07, 2007 12:47
Hello Alfisti
I'm writing from Italy (Modena) and I would ask your help for some technical information about the "Alfa 33 Savali" because I didn't find any information on internet about the enigne (bhp, torque and the flatcar)
I'm sorry for my bad English
Thank's a lot for your help :wink:
Bye!
Steven 33
RE: Alfa Romeo 33 Savali
za apr 07, 2007 13:04
Hi, fist of all, welcome to the forum!
Can you be a bit more specific about the information you want? Engine volume, injection or carburettor version?
Steven
Boxer33.mo
zo apr 08, 2007 12:38
Hi Steven
I did't know that there two versions(carburettor and injection), you can tell me the horse power and max torque of both versions?
Thank's :wink:
giulia-tom
ma apr 09, 2007 11:56
Hi !, this info can be found here: CLICK!
Look in the header at position 6 "INFODATABASE" , at the 2nd line you will find a review on the engines from all types of the 33. (Techniek Alfa 33) :thumbs:
nr: 2714
ALFACENTRO
Speeder
Re: RE: Alfa Romeo 33 Savali
ma apr 09, 2007 12:17
Unfortunately the tuned SAVALI engine isn't listed there... :roll:
'93 Alfa Romeo 33 1.4IE Boxer
Boxer33.mo
ma apr 09, 2007 15:46
Hello!
Thank's for this link,but i didn't find the Savali engines. I find the catalogue in squadra33
The size of engine was 2.0? :shock:
Mark Roffelsen
ma apr 09, 2007 20:56
That is because SAVALi is a well known Alfa dealer in Holland who tunes the engines themselves. I used to own a savali 166 3,5 V6 (280 HP) and an savali GT 3,7V6 (295 HP). To get more info you should send an email to mr Fred van Lingen at houten@samvanlingen.nl. Good luck
Sergio
ma apr 09, 2007 22:52
`Hi,
I do not have extra info apart from the brochure on the Squadra 33 webiste, so contact Van Lingen, they will probablu help you.
There have been a carburettor and an injection version. The 2.0l version has never been sold since after tests it turned out the cylinder walls were too thin and the engine blew.
After that they 'reduced' it to 1.8 l, but the 2.0l sign remained on those cars..... :?
'79 Spider 2000 Veloce
'88 33 1.7 QV
'93 33 1.7 iE S 16v SW Q4
33 SW corsa
Boxer33.mo
za apr 14, 2007 18:18
Thank's a lot for your help,i try to write an e-mail to Van Lingen :D
ma apr 16, 2007 00:02
Stond er niet destijds een repo van die van Alex in een of ander tupperware magazine?
Daar stonden alle specs bij, onder andere vmax 185 ivm de 1.3 versnellingsbak.
Aantal mogelijkheden binnen de Samfredo motor:
Gesmede Cosworth zuigers
Lichtere krukas
Grotere kleppen
Scherpe/hete nokkenassen
Aangepaste koppeling en vliegwiel
Iemand die het kan vertalen?
1290 SD '14
Frits
ma apr 16, 2007 22:40
Via babelfish altijd een aardige eerste opzet. Iemand die de nokkenas is het engels weet? Oja en krukas?
There then didn't repo of those stand of Alex in or other tupperware magazine?
There all specs assisted, among other things vmax 185 ivm 1.3 the acceleration barge.
Number of possibilities within the Samfredo engine:
Forged Cosworth pistons
lighter krukas
larger clack
sharp/hot Camshaft (nokkenas)
adapted link
and fly wheel
Someone whom it can translate?
Laatst gewijzigd door Frits op ma apr 16, 2007 22:45, 5 keer totaal gewijzigd.
ma apr 16, 2007 22:42
nokkenas is Camshaft
ma apr 16, 2007 22:51
Lichtere krukas
Grotere kleppen
So that is:
Lighter crank shaft
Larger valves
Sharp/hot camshafts
Modified clutch and flywheel
Stef33
ma apr 16, 2007 22:53
Lightened Crankshaft
Larger Valves
Wild Camshafts (?)
Modified Clutch and Flywheel
Laatst gewijzigd door Stef33 op ma apr 16, 2007 22:55, 1 keer totaal gewijzigd.
Stef
Stef33
Tik ik weer te langzaam. :wink:
Stef
