Alfetta GTV Dragster
specs:
BODY - GTV made completely made from carbon fiber/Kevlar. Weight before paint = 20kg INTERIOR - Carbon fiber CHASSIE - steel tube frame SHOCKS - rear: Öhlins coilover front: Koni BRAKES - Wilwood and Simpson WHEELS - Lamb frontrunner 4” with good year tires 4,5”, Weld alumastar 10” rear with M/H Racemaster 13/30” REAR AXEL - 9” prisma banjo with 35 splines Mark Williams axels, Mark Williams third member and alu spool, richmond gears 4,86 and 4,10 gear ratio GEAR BOX - Liberty pro stock 5speed clutchless, magnesium case CLUTCH - Hayes 8” pro stock clutch
ENGINE - 2lit ALFA ts, JE pistons 10,0, Autoverdi connecting rods, Monosleeve, modified engine block with mono barrel sleeve, Weaver dry sump pump, Polished orig alfa crank shaft, Kent cams (308 degrees, 426” in and 314 degrees ,441” out) Kmotion valve springs, Ferrea valves, titanium retainers. Head port matching job in cooperation with Andrew Wood in a superflow bench. NITROUS OXIDE SYSTEM - Nos Fogger METANOL INJECTORS - 8 x 2000cc@5bar FUEL PUMP - Weldon Metanol PRESSURE RELEASE VALVE - Weldon Metanol TURBO - Holset HX55 WASTEGATE - 2 x HKS 40mm EXHAUST MANIFOLD - own design INJECTION SYSTEM - Autronic SM2 with launch/ALS IGNITION SYSTEM - Missing at present
http://zen.sitecity.ru/album_2307101559.phtml
